  • KUIU HD Mud Boots Handle Tough Terrain With Surprising Support
    Read 1,890 times
(Photo/Jennifer Schmidt)
When you're covering serious miles in unpredictable terrain, your boots aren't just footwear; they're gear. And like any gear, they must perform, hold up over time, and keep you comfortable.
I wore the KUIU HD Mud Boots through an entire hunting season in Montana, putting them to the test across creeks, rocky ridgelines, deep snow, and muddy fields. After more than 50 miles of hiking in varying conditions, I have a good feel for what they do well and where they're lacking.
From daily chores, trips to the river, and trips to the field, these boots have become one of my go-to grabs on my way out the door. After a full season and then some, what are my thoughts?
In short: The KUIU HD Mud Boots are far more capable than I initially thought they'd be. They’re watertight, warm, comfortable, and supportive in ways my previous rubber boots haven't been. They're almost perfect if you overlook one little fit issue.
Looking for hunting boots? Check out our guide to the best hunting boots of the year.
    4 lbs., 10.6 oz. / 2,115 g (per pair, size 9)
  • Best use conditions:
    Cold to frigid weather
  • Waterproof:
    Yes
  • Windproof:
    Yes
  • Insulation:
    7mm neoprene boot construction
  • Lining:
    Bonded grid-fleece interior for added warmth
  • Support:
    ¾-length boot shank for enhanced stiffness and support
  • Outsole:
    Patent-pending self-cleaning EVA sole design
  • Price:
    $199
  • Warm
  • Comfortable
  • Supportive
  • Great traction
  • Waterproof
  • Front boot fold issue that caused rub spot
KUIU HD Mud Boot Review
First Impressions & Fit
Pulling on the KUIU HD Mud Boot by the handle
The KUIU HD Mud Boots offer a snug, supportive fit right out of the box, perfect for long hours in the field; (photo/Jennifer Schmidt)
Right out of the box, I was surprised by how comfortable they were. The fit was snug in a good way, not overly tight, but secure enough to feel supported without needing to lace anything up. I'd describe the sizing as true to size, but expect them to be more fitted than your average rubber boot or Muck-style option.
That tighter fit does make them a little harder to get off at the end of the day, but for me, the extra effort was worth it for the performance they gave in the field.
Terrain and Conditions Covered
KUIU HD Mud Boot standing in shallow river water
The KUIU HD Mud Boots excelled across mud, snow, creeks, and rocks, providing excellent traction on uneven terrain; (photo/Jennifer Schmidt)
I wore the KUIU HD Mud Boots across various terrain, including mud, rocks, snow, creek crossings, and dry fields. Originally, I planned to use them for early-season archery hunts in September, knowing I'd be crossing a ton of waterways on my particular hunts, but they quickly became my go-to throughout the fall and into late-season snow.
I used them to cross multiple creeks and never once worried about slipping or losing traction. The grip was solid, even in slick or uneven conditions. That was one of the standout features. These boots don't feel bulky or clumsy, which can sometimes be the case with rubber-style hunting boots.
Comfort & Performance Over Time
KUIU HD Mud Boot in dry grass and snow
These boots kept my feet dry and comfortable even after hours of wear, though swapping socks on warmer days was key; (photo/KUIU)
Overall, they were very comfortable for extended wear, though I found it helpful to swap out socks halfway through on warmer days, which is probably a good practice for most rubber boots to prevent moisture abrasions.
The fleece lining added a nice touch of warmth in colder weather, but if you're planning to be out in negative temps for hours, you'll want additional insulation or thicker layers. They kept my feet dry and warm in most conditions, and I never experienced heel lift or foot fatigue.
That said, one downside was the way the rubber folded at the front of the boot and rubbed against my shins during longer hikes. It wasn't a dealbreaker, but it's something to keep in mind if you plan to cover a serious distance in one day.
Support & Build
Bottom tread of the KUIU HD Mud Boot shown close-up
After over 40 miles of hiking, these boots are still holding strong with no signs of cracking or leaking; (photo/Jennifer Schmidt)
One of the biggest surprises with these boots was how much support they provided. Most rubber or mud boots I've used in the past tend to be flimsy around the ankle and arch, but the KUIU HD Mud Boots gave me the structure I needed while hiking across uneven ground. I never rolled an ankle or felt unstable, even with a full pack.
The boots are holding up well after a full season and over 50 miles of hiking. The tread is starting to show typical signs of wear, which is expected, but the body of the boots still looks practically new. There is no splitting, cracking, or leaking. For something that's been through creeks, snow, and rough terrain, that's impressive.
What I'd Improve
KUIU HD Mud Boot standing on dry forest ground
A slight rubbing issue at the front of the boot can cause discomfort during long hikes, especially when wearing jeans; (photo/Jennifer Schmidt)
If I could tweak anything, I'd address the rubber rubbing issue on the front shin area. After longer hikes, that contact point would start to cause slight discomfort. It didn't happen every time, but often enough that I noticed. I also wouldn't recommend these as your go-to for multi-hour hikes in extreme cold unless you're layering up.
It doesn't help that I'm a sucker for wearing jeans in the field. That being said, the rub issue happened on occasions when I was wearing denim, my hunting pants, and just directly on my skin while doing the mundane tasks that happen to require a pair of boots.
Best Use Case
KUIU HD Mud Boot worn during outdoor chores
These boots are great for hunters and outdoor workers needing reliable footwear in unpredictable environments; (photo/KUIU)
These boots are ideal for anyone looking for reliable footwear in wet, variable conditions. I think they shine during early to mid-season archery hunts or for situations where you're going to be in and out of water and mud, but not covering 10+ miles a day. These would be perfect boots for trudging through the muck and brush to your treestand.
I'd recommend them to other hunters or outdoor workers who need a boot that can handle harsh environments without breaking down after one season. They'd make a great ranch boot.
For $199, the KUIU HD Mud Boots deliver a lot of value. They've become a reliable piece of gear for me, and I expect them to last several more seasons. The waterproofing, support, and durability all met and exceeded my expectations.
While they're not perfect, mainly due to some comfort quirks during long hikes, I'd definitely buy them again if I needed a solid boot for wet, unpredictable terrain.
Editor’s Note: These boots were tested by a rugged hunter and outdoorsman who isn’t a writer. That tester relayed his firsthand experience to the author. The author was present during testing.
Crispi Colorado hunting boot tread
The Best Hunting Boots for Men of 2025
Whether you're hunting moose in the Yukon or wing-shooting pheasants in South Dakota, we've rounded up the best hunting boots of the year. Read more…
Source: KUIU HD Mud Boots Handle Tough Terrain With Surprising Support
  • Waterproof:
    Yes
  • Windproof:
    Yes
  • Insulation:
  • Lining:
  • Support:
  • Outsole:
  • Price:
    $199
  • Warm
  • Comfortable
  • Supportive
  • Great traction
  • Waterproof
Support & Build
What I'd Improve
Best Use Case
