  • ‘Jump Off Everything’ Energy: Rome Stale Crewzer Snowboard Review
    Read 2,589 times
'Jump Off Everything' Energy: Rome Stale Crewzer Snowboard Review
(Photo/Eric Phillips)<br>
When I strap into the Rome Stale Crewzer snowboard, I start to interpret the terrain in a different way. Under my feet, this design feels confidence-inspiring, poppy, and impact-absorbing. With it, the mountain has become my park: I look for side hits and playful features. While I’m not a dedicated Slopestyle master, the Stale Crewzer inspires me to explore the slopes with a jump-off-everything energy.
Stale Sandbech is known as one of the best park and freestyle snowboarders in the sport’s history. And this design is his 10-year anniversary pro model board, so my on-snow experience makes sense.
The model was revamped to be more directional last winter season. For 2025-26, it has a larger, rounded nose and smaller, rounded tail, delivering a more comfortable shape for all-mountain riding.
After my first few days on the Stale Crewzer, I found myself charging harder down the mountain. The design motivates me to look for any opportunity to get air, go bigger, land deeper, and repeat.
I revered this profile and shape for all-mountain days across Crested Butte Mountain Resort, from the park to the glades, moguls, and Extremes.
In short: The Rome Stale Crewzer ($550) is a park and all-mountain snowboard, designed by legendary snowboarder Stale Sandbech to be the ultimate daily driver. Underfoot, this freeride board feels fast, poppy, playful, and responsive. It’s built to tackle park laps, steeps, side hits, and even holds its own in powder.
See how this board stacks up against the rest of the rack in our Best All-Mountain Snowboards buyer’s guide.
  • Profile:
    Fusion Camber / Rocker – Camber – Rocker
  • Shape:
    Directional twin
  • Flex:
    6 (Medium hard)
  • Base:
    Sintered
  • Sizes (cm):
    152, 155, 158, 159w, 161, 162w
  • Excels in the park and on side hits
  • Stable in the steeps
  • Impact plates for additional impact absorption
  • Not the best in powder
Rome Stale Crewzer All-Mountain Snowboard: Shape & Profile
Hitting a decade on the slopes and receiving an upgrade, the Crewzer has a directional twin shape. Why is it directional? The board has a larger rounded nose and a smaller rounded tail to help direct speed and power in one direction. A true twin, on the other hand, has a nose and tail with the same size, enabling equal energy in either direction.
In that case, what makes this a twin? There’s no setback. And the bindings are mounted directly in the center of the board, creating the same distance from your front binding to nose as the back binding to tail.
When facing forward, this board charges hard. I also found that the larger nose and smaller tail helped me float better in powder. But much like Stale's style, this board isn’t afraid to ride switch, either. I was able to pull off switch landings and takeoffs, and to enjoy backfoot forward riding.
That directional twin shape is matched with a fusion camber profile. What stood out to me most was the large pocket of traditional camber underfoot, which is paired with rocker at the tip and tail.
The underfoot camber led to extra pop and a playful performance in jumps and turns. The rocker in the tip and tail helped with float in powder, while also delivering a faster turn initiation for high-speed ripping.
Construction
The Stale Crewzer has a couple of unique layers in its core construction, which I really appreciated on snow. Sandwiched between its poplar core are two freeride technologies.
The first: A set of carbon “HotRods.” There are two 12-inch-long carbon rods. Each section starts underfoot and heads toward the tip and tail. These rods of carbon store and release energy, delivering that poppy personality and increasing responsiveness.
A snowboarder mid-grind on a rail feature at Crested Butte
The clean white topsheet stands out against the snow, while the bold base graphic turns heads in the air; (photo/Eric Phillips)
The second technology is a set of flax impact plates. These duos help with impact absorption on harder impacts and bigger landings. Additionally, these plates help with durability — so you can send it again and again.
Durability
During a few consecutive days on the Crewzer, I took the board through low-tide, rocky terrain. I also rode a handful of rails and boxes in the park. I was impressed with its durability and impact performance.
Despite jumping off everything possible, the board has no dings, marks, or scratches. It gives me a solid impression of durability and confidence in the board’s lifespan.
Base & Topsheet
On the face of the board, the bright yet plain top sheet and graphic stand out.  At first, I wasn’t sure I liked the all-white surface, but quickly found it pairs well with almost any kit color. It also stands out against a snowy white backdrop. The simple graphic and light color feels clean. The stormy artwork makes me think of power building, ready to release its explosive energy.
With the amount of airtime this board will have, you’ll be showing the base off. It’s a deep purple with a larger version of the top sheet’s graphic: A lightning bolt running tip to tail.
Critiques
While this snowboard excels in the park and at all-mountain freeriding, there are a few places where the board doesn’t feel the best. First, this is not a board for deep, laid-over carves. With a waist width of only 26 cm on the wide version, I found myself getting toe or heel drag whenever I leaned far over into an arch.
Additionally, while this snowboard can handle powder conditions, I wouldn’t consider it a powder board. If you spend a considerable time riding powder, a board with a larger nose and tail, and a rearward setback will lead to easier float. Knowing this board’s weaknesses, you can either avoid these conditions altogether or adjust your riding style.
A snowboarder holding the Rome Stale Crewzer with the Crested Butte ski area in the background
The Rome Stale Crewzer isn't ideal for deep carves — its narrow waist width can cause toe or heel drag; (photo/Eric Phillips)
Conclusion: Who’s This Snowboard For?
Plain and simple, this board is for those who want to ride like Stale Sandbeck. If you’re looking for a park board that can also handle shredding when things get steep or deep, this Rome staple is it.
No matter what I point this board at, it comes off the lip with so much pop. Landings are more of a breeze thanks to the flax impact plates, giving me confidence to go further and higher. I see this as a great board to have in my quiver for my aging knees and ankles, helping me prolong my career of jumping off things with my snowboard.
This all-mountain snowboard excels at side hits, spins, rails, jumps, blasting ollies, and powerful landings. Whether I was on the slopes or in the park, this board delivered a real freeride experience across the whole mountain.
Overall, the Rome Stale Crewzer is a hard-charging directional twin board aimed at handling a diverse range of snow conditions while balancing a playful, precise feel. While it doesn’t hold up in powder like a true powder board, it’s still plenty of fun charging around the resort.
The Best All-Mountain Snowboards of 2025
Our experts tested the best all-mountain snowboards. Top picks include GNU, Burton, and more. Read more…
Source: 'Jump Off Everything' Energy: Rome Stale Crewzer Snowboard Review
  • Profile:
  • Shape:
    Directional twin
  • Flex:
    6 (Medium hard)
  • Base:
    Sintered
  • Sizes (cm):
Construction
Durability
Base & Topsheet
Critiques
