  • Camping Survival Tips to Help You Handle the Great Outdoors
    Read 3,752 times
Camping deep in the wild is an adventure unlike any other. There are no paved roads to travel, no designated campsites to pitch your tent, and no friendly park rangers to keep an eye on things. However, this freedom to take the path less traveled comes with responsibility. When you are miles away from help, every choice matters. You need to find safe shelter, secure clean water, and you'll also need to steer clear from wild animals. If you plan on heading off-grid, make sure you're ready with these essential camping survival tips.
Camping Survival Basics Every Beginner Needs to Know
June is National Camping Month, and that means more people heading outdoors. Let's go over some smart, doable camping survival tips.
Shelter: Stay Dry, Stay Hidden, Stay Alive ️
A well-built shelter protects you from harsh weather, keeps your body temperature stable, and helps you stay unnoticed. If you choose the wrong spot or fail to build a sturdy shelter, you risk exposure to heavy rain, harsh winds, or dangerous wildlife.
Choosing a Safe Campsite
  • Avoid low ground. Rainwater naturally flows to low areas such as dry riverbeds, valleys, and canyons. Even if there are clear skies where you are, rain from miles away can unleash a flash flood down these spots. If you camp in one of these places, you may not have enough time to escape before the water arrives.
  • Set up camp on slightly elevated terrain. Water naturally drains downhill, so lower areas become muddy and waterlogged after rain. However, camping on steep slopes is also risky because water can flow quickly and erode the ground. A gentle slope is the best option as it allows water to drain naturally which decreases the risk of erosion.
  • Look for natural windbreaks. Large rocks, tree clusters, or thick bushes block strong winds and help keep your shelter intact during a storm. If no natural protection is available, stack logs or pile up brush to create a barrier.
Building a Shelter That Works in Any Weather
If you don't have a tent, you can build an emergency shelter using whatever is available around you.
  • Lean-to Shelter: Find a sturdy branch and rest one end against a tree trunk. Lean smaller branches against it at an angle. Then, cover them with leaves, grass, and bark to block wind and rain. A lean-to works well if you only need partial cover and want an open view of your surroundings.
  • Debris Hut: Pile up a mound of leaves and sticks and shape them into a small, enclosed space to trap heat. A debris hut is best for cold weather because the thick insulation helps keep warmth inside.
  • Tarp or Poncho Shelter: If you have a sturdy tarp or extra blanket, tie it between trees to create a waterproof cover. Angle one side lower than the other so rainwater will run off and won’t pool in the middle of the tarp.
Water: Find It, Purify It, Stay Hydrated
Dehydration affects your ability to think clearly and move efficiently. It also helps you regulate your body temperature. However, drinking untreated water can be just as dangerous as dehydration because bacteria, parasites, and viruses can lead to severe illnesses.
Finding Water Sources That Won't Make You Sick
  • Look for running water. Streams and rivers are in constant motion, which helps flush out bacteria and other contaminants. When water remains stagnant, like in ponds or puddles, it becomes a breeding ground for parasites, algae, and microbes.
  • Follow animal tracks and insect activity. Many animals, especially deer, drink from reliable water sources. If you notice hoof prints, game trails, or droppings, that means you may be close to a stream or pond.
  • Search for water at low points in the landscape. Hill bases and rock crevices hold moisture longer than flat or high ground. If you notice an area with green, healthy plants in an otherwise dry landscape, there may be water underground. Dig in the damp soil to reach the groundwater.
Purifying Water To Be Extra safe
Even if the water looks clear, it may contain harmful microorganisms that cause life-threatening illnesses. Stay safe by always purifying your water before drinking.
  • Boiling: When water reaches a rolling boil, the heat destroys harmful microorganisms. Boil water for at least one minute to ensure safety.
  • Filtration: Use a portable water filter to remove bacteria and sediment. If you don’t have one, you can create a simple filter by layering sand, charcoal, and cloth inside a container and pouring water through it. Additionally, filtration only removes debris but does not kill harmful organisms.
  • Purification Tablets: Use iodine or chlorine tablets to kill bacteria, viruses, and parasites. Most purification tablets take between 30 minutes to four hours to kill all pathogens. They’re especially useful when boiling or filtering is not an option.
Staying Hidden: Avoiding Both Animals and People
Some situations require stealth for safety if you need to avoid curious wildlife or keep a low profile from other people.
Keeping Wildlife Away From Your Camp
Wild animals rarely approach humans unless they smell food or sense an easy meal.
  • Store food far from your sleeping area to keep animals away. Place all food, trash, and scented items in a sealed bag then hang it from a tree at least 10 feet off the ground and 100 yards away from camp. This prevents animals from smelling and accessing your supplies.
  • Cook away from your shelter to avoid drawing predators. The scent of food travels far, especially in calm or humid air. Prepare meals at least 100 yards from your sleeping area, and avoid spilling grease or scraps that could leave lingering smells.
  • Dispose of food waste properly so animals are not drawn to your camp. If you bury food, some animals may still pick up the scent and dig it up. The safest option is to burn food scraps in a controlled fire or bring them with you via a sealed container.
Avoiding Unwanted Human Attention
Not everyone you meet in the wild has good intentions. Some people may be curious, while others might pose a real threat. Take these steps to stay unnoticed and protect yourself.
  • Choose a hidden campsite to reduce the chance of being found. Avoid setting up near well-traveled trails, river areas, or open fields because these spots attract hikers, hunters, and campers. Look for dense vegetation, rocky terrain, or natural barriers that block visibility. The harder your camp is to see, the less likely someone will stumble upon it.
  • Use neutral-colored gear to blend into your surroundings. Flashy tents, bright backpacks, and colorful clothing stand out in the wild and make you easy to spot. Instead, use earth tones like brown, green, and gray to blend in with the surroundings.
Camping Survival Tips: Stay Safe and Enjoy the Wild
Wild camping is one of the most rewarding ways to experience nature. However, it's also a test of skill, preparation, and awareness. The right shelter, clean water, and effective stealth can mean the difference between a peaceful night under the stars and an unplanned camping survival situation.
FAQs: Camping Survival Tips
  1. What's the best emergency shelter if I get lost?
    A debris hut is the easiest to build. Pile leaves and branches for insulation.
  2. How much water should I carry?
    At least one gallon per person per day. But always look for more sources.
  3. Are there any survival tools I should always have?
    Yes! A knife, fire starter, water filter, and emergency blanket should be in your pack.
  4. What's the best way to keep food safe from bears?
    Hang it 12 feet up and 6 feet from the tree trunk. Use a bear-proof bag if possible.
  5. How do I make a fire without matches?
    Use a ferro rod, magnifying glass, or even friction methods like a bow drill.
Source: Camping Survival Tips to Help You Handle the Great Outdoors
