  • 72-Hour Survival Challenge: Can You Make It Out There?
    Read 3,780 times
Many preppers believe their bug-out bags are ready for any kind of emergency. Unless they test their gear in real conditions, they have no proof that it will work as expected. This 72-hour survival challenge will reveal weaknesses in your gear, skills, and mindset before a real crisis forces you to rely on them.
With only your bug-out bag contents as your supplies, can you make it past 72 hours alone in the wild? You cannot buy additional food, use household conveniences, or add supplies once the challenge starts. In case you forget to bring an essential item, you'll have to adapt and find a way to manage.
Why 72 Hours?
The first 72 hours after a disaster present the most significant survival challenges. During this period, you must think quickly and solve problems with limited resources. Here are the key dangers you face:
  • Blocked or dangerous roads. Floods can wash out bridges, fallen trees can block highways, and debris can make some routes impassable. If you need to evacuate, you must prepare to travel on foot with a fully loaded pack.
  • Overwhelmed emergency services. Paramedics treat critical injuries, police respond to public disturbances, and firefighters manage structural damage. If you need urgent medical attention, you may have to rely on your first-aid skills as hospitals are overwhelmed.
  • Limited access to food and water. Grocery stores close when power outages occur, supply trucks stop deliveries, and panic buying empties shelves. Once people begin looting stores, you won't find anything left and will have to survive on emergency rations.
Rules of the 72-Hour Survival Challenge
This challenge is only useful if you follow the strict guidelines. Following the rules helps you create a realistic survival experience and accurately test your preparedness:
  • Use only the supplies in your bug-out bag. Use only what you packed beforehand. During the 72-hour challenge, you cannot add extra items or retrieve forgotten gear.
  • Survive for 72 hours. You must locate food, secure drinking water, build a fire, and set up shelter using only the equipment you packed. Your survival skills will determine your success because no outside help is allowed.
  • Document everything. Write daily reflections in a survival journal, take photos of your shelter setup, and record short videos showing you using tools. This documentation will help you review what worked and what failed.
Choosing the Right Location
The location you choose will determine the challenge's difficulty. Various options provide different levels of realism and safety:
  • Backyard. This option works best for beginners because it allows them to test their bug-out bags in a safe environment. The participants must still rely only on their packed supplies, but they have an emergency exit if something goes wrong.
  • Local Wilderness or State Park. This is a more realistic test that requires staying in a natural environment where no modern conveniences exist. This setting forces participants to set up shelter, gather food sources, and purify drinking water using whatever equipment they carry.
  • Remote Location. This option suits experienced survivalists who can handle unpredictable weather and extreme isolation. Participants must rely on their fire-starting skills to stay warm and cook food. They also need to navigate the landscape without GPS assistance.
Breaking Down the Survival Essentials
Your bug-out bag must provide solutions for every essential survival need. Here's what a real 72-hour survival challenge looks like and how to prep.
1. Fire
Fire is critical for keeping you warm, cooking food, purifying water, and signaling for help. Here’s how to test your fire-making ability:
  • Use your fire-starting tools. Light a fire with a lighter in wet conditions, strike a ferro rod on damp wood, and use waterproof matches in the wind. If one method fails, test another option to determine which works best in different environments.
  • Gather and ignite natural tinder. Collect dry leaves under trees, peel bark from fallen branches, and break apart dead grass to see which burns the fastest. If you struggle to start a fire, pack better tinder alternatives such as cotton balls soaked in petroleum jelly.
  • Build and maintain a fire. Arrange small twigs in a teepee structure, feed it with progressively larger branches, and shield it from the wind using rocks. If the fire burns out too quickly, adjust the setup to maintain a steadier flame.
2. Water
A steady water supply is essential in staying hydrated for 72 hours. Without adequate water, you’ll lose energy and find it harder to complete essential tasks. Here’s how to determine if you have a sufficient water plan:
  • Measure your water supply. Track how much water you drink each day. Mark a bottle, estimate how long your stored water will last, and calculate your daily needs. If you run out too soon, pack a larger reserve or plan for alternative water sources.
  • Use your water filtration system. Collect water from a river, filter it through your survival pump, and purify it with iodine tablets. If filtration takes too long or fails to remove impurities, try a different purification method.
  • Boil water as a backup method. Heat water in a metal container until it reaches a rolling boil, maintain the boil for at least a minute, and let it cool before drinking. If boiling consumes too much fuel, adjust your fire setup or find another purification method.
3. Shelter and Warmth
A secure shelter protects you from harsh weather. Exposure to cold and moisture can weaken your body and your risk of illness. Here’s how to test your shelter system:
  • Set up your tent before dark. Assemble it in daylight to avoid fumbling with poles and stakes in low visibility. If setup takes too long, practice until you can do it quickly without instructions.
  • Monitor overnight temperatures. Sleep inside your sleeping bag, check if it provides enough warmth. If not, add thermal layers as needed. If you wake up cold, improve insulation by inserting a sleeping pad or adding an emergency blanket.
  • Check for wind and rain protection. Position your shelter near natural barriers to block the wind by facing your tent entrance away from strong gusts and securing the tarp tightly. If rain seeps inside, reinforce your waterproofing by using extra groundsheets.
Are You Ready?
This 72-hour survival challenge will reveal the truth about your survival readiness. If you complete it successfully, you will gain confidence in your abilities. If you struggle, you'll learn important lessons that could save your life.
Will you take the 72-hour survival challenge? If you do, share your experience. The best way to improve is to test yourself now before you face situations where your life depends on how prepared you are.
FAQs: Your 72-Hour Survival Questions Answered
  1. Can I bring my phone?
    Yes, but only for emergencies or documentation. Do not use it to cheat.
  2. What if I run out of water?
    Plan ahead. Have a filter or purification method ready.
  3. Can I hunt or fish?
    If local laws allow and you have the skills, yes. But for three days, packed food is usually a safer option.
  4. What if I have to quit?
    If you must quit, that's okay. Learn from your mistakes, adjust your bag, and try again.
  5. Can I bring extra clothes?
    Only if they are in your bug-out bag when you start.
Source: 72-Hour Survival Challenge: Can You Make It Out There?
Why 72 Hours?
1. Fire
2. Water
Are You Ready?
