  • Summer Blackout Survival Guide: Here’s How to Prepare
    Read 3,783 times
Summer Blackout Survival Guide: Here's How to Prepare
Summer is approaching, so expect extreme heat to make an appearance as well. If recent years have shown us anything, it's that power grids struggle under the increased demands for electricity to power air conditioners and other cooling systems. Aging infrastructure amid prolonged heat waves push the power system to its limits. As a result, rolling blackouts cause transformers to fail and leave neighborhoods sweating during many summer nights. So, are you prepared when the lights go out this summer? Let's break down how to stay cool and make it through a summer blackout without breaking a sweat.
1⃣ How to Keep Your Home Cool Without Power
A summer blackout can make your home unbearably hot and increase the risk of heat exhaustion, severe dehydration, and heat stroke for its residents. Here are a few tips to block the heat and stay comfortable.
Block Out the Sun ☀
  • Cover sun-facing windows with blackout curtains, heavy blankets, or aluminum foil. These materials help block sunlight and reduce indoor temperatures to keep rooms cooler.
  • Use exterior shade like awnings, outdoor blinds, or shade cloths to stop heat before it reaches your home.
  • Keep interior doors closed to trap cooler air, prevent heat from spreading, and maintain a comfortable temperature.
Use DIY Cooling Tricks ❄
  • Create an evaporative cooler by soaking a sheet in cold water and hanging it in a breezy, cross-ventilated space. This method works best in dry, low-humidity climates.
  • Freeze water bottles, damp towels, and cooling packs before a blackout. When the power goes out, place one on your neck, wrists, or ankles to help lower your body temperature.
  • Make an ice-bowl fan hack by placing a deep bowl or metal pan filled with ice in front of a battery-powered fan. As the ice melts, the fan blows cool air and reduces indoor heat.
2⃣ Off-Grid Power Solutions: What Actually Works?
A blackout doesn't have to mean total darkness, dead appliances, and empty batteries, and . The right off-grid power sources can keep lights on and charge devices.
Solar Power
  • Portable solar panels can recharge small devices like phones, radios, and battery packs when placed under direct sunlight.
  • Solar generators provide a quiet, fuel-free way to power fans, LED lights, and small refrigerators.
  • DIY solar ovens allow you to cook meals using sunlight. To build one, use a black interior, add reflective panels and an insulated glass cover to trap heat effectively.
Battery Backups & Power Banks
  • Large battery stations like Jackery or Goal Zero can store huge amounts of electricity and run mini-fridges, fans, and laptops for hours.
  • Rechargeable battery packs are great for flashlights, radios, and USB-powered devices. Charge a few extra batteries when there's a power outage advisory.
  • Car power inverters allow you to charge phones, tablets, and other essential devices with your car battery. Start the engine periodically to avoid draining the battery.
Gas & Propane Generators
  • Gas-powered generators can keep your fridge, fan, and lights running. However, not all generator models can handle the high start-up wattage of an A/C unit. Always check your generator's wattage before hooking your appliances.
  • Propane stoves let you cook, boil water, and sterilize supplies by providing consistent heat even during blackouts.
3⃣ How to Keep Food from Spoiling
A power outage stops your fridge from cooling and makes your freezer start thawing. When these things happen, your food will spoil and cost you hundreds of dollars wasted groceries.
Before a Blackout:
  • Freeze one-gallon water jugs, two-liter bottles, and extra ice packs. They act as ice blocks in your cooler and help keep your fridge temperatures lower longer.
  • Set your fridge and freezer temperature to the coldest setting before a heatwave. Doing so can buy you extra time when the power goes out.
  • Stock up on non-perishable foods because they don't require refrigeration, which eliminates the need for cold storage.
During a Blackout:
  • Keep the fridge and freezer doors closed as much as possible. An unopened fridge stays cold for about 4 hours while a full freezer can last up to 48 hours without power.
  • Move perishable foods into a cooler filled with frozen water jugs, sealed ice packs, and insulated blankets if you expect the outage to last for more than a day.
  • Use a food thermometer to check temperatures. If food reaches above 40°F for more than 2 hours, toss it! It's not worth the risk of food poisoning.
4⃣ Stay Hydrated & Avoid Heat-Related Illnesses
When temperatures soar, your body loses water through sweat. At the same time, your heart works harder while your internal cooling system struggles to keep up. Recognizing the signs early and knowing how to cool down effectively can prevent heat-related conditions.
Signs of Heat Exhaustion:
  • Dizziness, headache, and excessive sweating
  • Muscle cramps, nausea, and feeling weak
  • Cool, clammy skin despite the heat
How to Stay Hydrated & Cool:
  • To prevent dehydration, allocate 1.5 to 2 gallons of water per person daily for their drinking needs.
  • Drink water consistently throughout the day instead of only doing so when thirsty.
  • Eat water-rich foods like watermelon, cucumbers, and celery to supplement your water intake.
  • Apply wet cloths, cooling towels, and ice packs on your neck, wrists, and feet to cool your body quicker.
Summer Blackout Season Is Here: Will You Be Ready?
Every summer, people assume that electricity is available…until it isn't. Those who planned ahead can just sit back and wait out for the lights to come back on. Conversely, those who did nothing will most likely struggle against hunger, heat, and exhaustion. When the grid fails, survival belongs to the prepared.
5 Frequently Asked Questions (FAQs) About Summer Blackout Survival
1⃣ How long can a fridge keep food cold during a summer blackout?
➡ About
4 hours for a fridge, 48 hours for a full freezer if unopened.
2⃣ What's the best way to cool down without A/C?
➡ Block sunlight, create cross-ventilation, use ice packs on pulse points, and stay hydrated.
3⃣ Can I run my A/C on a generator?
➡ Most
portable generators can't handle central A/C but may support a window unit—check wattage requirements.
4⃣ What's the best battery backup for power outages?
Large battery stations (Jackery, Goal Zero) work well for CPAPs, fans, and small electronics.
5⃣ How do I know if food is still safe to eat?
Use a thermometerif food is above 40°F for over 2 hours, toss it.
Source: Summer Blackout Survival Guide: Here's How to Prepare
Block Out the Sun ☀
Solar Power
Before a Blackout:
During a Blackout:
➡ About
➡ Most
