  • Master the Seated Ab Pike Compression: The Ultimate Deep Core and Hip Flexor Exercise for Serious Lifters
    Read 2,758 times
Ripped abs are one thing, and core strength is another. You can have one without the other, but wouldn't it be great to have both? If you want core strength—the kind that unlocks advanced movements, improves lifting performance, and helps develop a six-pack—you need the Seated Ab Pike Compression.
At first glance, it seems simple: Sit down, press your hands into the floor, and lift your legs. But once you're in the middle of it, you realize it's a tough blend of mobility, stability, and compression strength. It targets the deep core muscles, focusing on the transverse abdominis and hip flexors, while improving postural muscles and full-body tension.
And the best part? No equipment needed. If your current ab routine isn't cutting the mustard, the Seated Ab Pike Compression will level it up. Let's dive in.
_PB66323 ©PERBERNAL
28 Days to Six-pack Abs Workout Program
This detailed routine is designed to help you carve a washboard stomach while building a tapered phy...
Read article
What is the Seated Ab Pike Compression Exercise?
The Seated Ab Pike Compression involves sitting upright with your legs straight in front of you, pressing your hands into the floor, and lifting your legs off the ground while maintaining good posture. It combines an L-sit, a hollow-body hold, and a mobility test all in one. If your hamstrings are tight or your hip flexors are weak, you'll find out right away. If your posture is off, you'll fold like a deck chair.
How To Do It
This exercise focuses on creating maximum tension with little movement. Attention to detail is crucial, including your posture, leg positioning, and the ability to maintain position without folding.
Here's how to do it right.
  1. Sit on the floor with your legs extended straight in front of you, feet together and pointed forward. Keep your back upright and your hands on the floor next to your thighs.
  2. Press your hands firmly into the ground. Think about driving your shoulder blades down and away from your ears. Engage your core, quads, and hip flexors like you're trying to "shorten" the distance between your ribs and thighs.
  3. Without leaning back, lift your heels just off the ground while keeping your knees straight and pause for 1–3 seconds. Then lower with control.
  4. Reset and repeat for desired reps.
Too hard? If lifting both legs is too challenging, keep one heel on the floor and focus on alternating lifting one leg at a time while maintaining posture and tension.
Too easy? Once you're a pro, raise your hands on yoga blocks or parallettes for a greater range of motion. You can also hold the top position longer, or inch your hands forward to decrease your leverage and make it harder to lift your legs.
Seated Ab Pike Compression Muscles Worked
The Seated Ab Pike Compression is a slight movement, but the muscular recruitment is anything but. Here are all the muscles it trains.
  • Transverse Abdominis: This muscle wraps around your torso like a built-in weightlifting belt. It stabilizes your spine and helps you create the compression needed to lift your legs.
  • Rectus Abdominis: These kick in to flex the spine and keep your chest up while your legs rise.
  • Hip Flexors: These muscles raise your legs up and keep them extended while your RA pulls everything together.
  • Quadriceps: Here, the focus is on the rectus femoris, which crosses both the hip and the knee. Keeping your legs straight under tension makes the quads work hard to stop the knee from bending.
  • Obliques: These assist in stabilizing your torso and preventing rotation or leaning during the lift.
  • Lats and Triceps: If you're pressing down hard into the floor, your lats and triceps make that happen, improving overall tension and shoulder stability.
Benefits of Seated Ab Pike Compression
There has to be a significant benefit to offset the discomfort this exercise causes. Don't worry, there is.
Targets Deep Core Muscles
Many ab exercises focus on flexion, rotation, or anti-rotation; this one zones in on isometric compression, the ability to shorten the space between your ribs and hips. Doing this means enhanced activation of the transverse abdominis and psoas, resulting in improved core strength.
Improves Hip Flexor Strength and Endurance
Weak hip flexors can limit athleticism, contribute to low back pain, and tank your squat or deadlift performance. This move strengthens them under tension and teaches them to work in harmony with your abs.
Reinforces Hollow Body Positioning The pike compression is similar to a hollow hold in motion, a cornerstone in gymnastics, calisthenics, and athletic performance. Building this position carries over to exercises such as planks, hanging leg raises, L-sits, and Olympic lifts.
Boosts Mobility and Hamstring Flexibility
To pull this move off, you need both hamstring flexibility and the ability to lift your legs high without back compensation. That combination of mobility and active control is a double whammy you are sure to enjoy.
Common Mistakes and Fixes
Without control and intent, the benefits disappear fast. Here are the most common mistakes and how to fix them for your ab pleasure.
Leaning Back
Tilting the torso backward makes the leg lift easier, which turns this into a poor imitation of a V-sit. Fix: Stay tall and brace your core. Think about pulling your ribs toward your thighs without changing your upper body position. Keep the chest up and spine neutral.
Using Momentum Instead of Compression
Swinging your legs up instead of using your hip flexors or bouncing off the ground to initiate the movement. Fix: Pause before beginning each rep. Drive the hands down, engage your quadriceps and abdominal muscles, and lift with control.
Bent Knees
Allowing the knees to bend while lifting or lowering your legs reduces the lever length, making the movement easier. Fix: Lock out your knees and squeeze your quads. Point your toes and think "tight from thighs to feet."
Losing Good Posture
Slumping forward and letting your shoulders and upper back round, which kills core engagement and means saying goodbye to all the benefits mentioned above. Fix: Sit tall, press your hands down, and keep your shoulders back and down.
Programming Suggestions
The Seated Ab Pike Compression works well as a warm-up exercise, a mid-workout core drill, or a finisher to smoke your abs and hip flexors.
Sets and Reps
Just staring: 2-3 sets of 6 short holds of 1–3 seconds per rep, one leg at a time if needed.
Feeling more comfortable: 3 sets of 8 reps with both legs lifted with 3-5 second holds at the top.
You're a pro: 3–4 sets of 10+ reps or longer holds of 5 + seconds per rep with hands closer to the knees.
Take 60 seconds between sets to reset and then repeat.
Source: Master the Seated Ab Pike Compression: The Ultimate Deep Core and Hip Flexor Exercise for Serious Lifters
_PB66323 ©PERBERNAL
Read article
How To Do It
Leaning Back
Bent Knees
Losing Good Posture
Sets and Reps
