  • Griffin Armament’s NEW 3d Printed Optimus 6 Suppressors
    Read 2,042 times
Griffin Armament's NEW 3d Printed Optimus 6 Suppressors
Griffin Armament has brought out their first 3d printed low backpressure suppressor with the new Optimus 6. This is a 6mm capable suppressor that has been optimized for the 5.56mm AR-15 platform, but is capable of handling up to 6mm Arc. Made with complex internal baffle geometries only capable with a 3d printer, this new suppressor has low backpressure and exceptional flash reduction. Made of 17-4 H900 Heat-treated Stainless steel, this full-auto rated suppressor is available in 3 mounting options (Dual-Lok, Griffin Taper, and 1.375×24 HUB), and two colors (Black or FDE). And if you’re concerned about possible a new Form 4 and repair issues that come from this being a 3d printed can don’t be, the Optimus 6 has an easily replaceable core that is welded to the serialized housing.
Suppressor Coverage on AllOutdoor
The Optimus 6 endcap has also been specifically designed for reducing flash signature, a common issue with low-back-pressure suppressors. A unique quad-prong end cap makes for a highly competitive level of flash suppression in the LBP suppressor market. So even if you are out chasing hogs under NODs, you shouldn’t have to worry about washing out your tubs when taking your shots. Every Optimus 6 suppressor features Griffin’s Perpetual Lifetime Warranty, MSRP starts at $699.95 and goes up to $869.95 depending on which mounting system you choose.
Griffin Armament Optimus 6 Suppressor Key Features
  • Low Backpressure – Rated up to 6mm ARC
  • Additive Manufactured Baffle Stack, End Cap, and Tube Body
  • Machined Mounting Interface and external diameter
  • Full 17-4PH Heat-Treated Stainless Steel Construction
  • High-Temp Cerakote Finish (Black or FDE Available)
  • Choice of Mounting System: DUAL-LOK®, Taper Mount, or HUB
  • Full Auto Rated (60 rounds then allow to cool to ambient temperature)
  • High-Flow FlashKiller End Cap Provides Exceptional Flash Reduction
  • Perpetual Lifetime Warranty
  • Caliber – 6mm
  • Diameter – 1.73″
  • Mounting System – Dual-Lok, Taper Mount, or Hub (1.375×24 TPI)
  • Overall Length – 6.68″, 6.59″, 6.02″
  • Weight – 17.2 oz, 16.5 oz, 15.2 oz
  • Colors – Black, FDE
  • MSRP – $699.95 – $869.95
  • Available – Summer 2024
The post Griffin Armament’s NEW 3d Printed Optimus 6 Suppressors appeared first on AllOutdoor.com.
Source: Griffin Armament's NEW 3d Printed Optimus 6 Suppressors
  • Caliber – 6mm
  • Diameter – 1.73″
Similar topics (4)
