  • 5 Need-to-Know Preventative Maintenance Tips for Off-Roaders
    Read 201 times
Off-roading is a fun outdoor activity that brings you closer to nature and your favorite transport. When you get back from the trails, it's essential to remember post-trip upkeep. Ignoring the cleaning and repairs could cause long-term damage due to otherwise preventable factors. What should you prioritize? Here are five preventative maintenance tips for off-roaders.
1. Preventative Maintenance – Replace the Air Filters
The first consideration should be your air filters. Experts say to change them every 30,000-45,000 miles, though the timeline differs for off-road enthusiasts. Driving through dirt, mud and sand quickly clogs the filters and necessitates more frequent service. Your replacement schedule should include inspecting them after every trip or at least once a month.
The air filter is important because it traps dirt and contaminants entering your engine. Without it, your off-roader's performance will significantly decline. Other components deserving your attention include the radiator and cylinder heads. Inspect these parts to ensure they don't have cracks or leaks, which would open the door to more damage.
2. Preventative Maintenance – Inspect the Suspension
Off-roading means driving on uneven terrain, rocks and other challenging surfaces. While the ride is fun, it taxes your suspension and warrants an inspection afterward. First, check the condition of your shock absorbers and springs because they could take a beating. Preventing this damage is more manageable with a lift kit so your vehicle is higher off the ground.
The next inspection round should include your tires, considering they're the only component touching the ground. Check the psi to ensure your tire doesn't have unwanted holes and leaks. If this problem arises, you can fix it with tire sealant and a leak preventer. This trustworthy tool has had military and industrial applications, making it a trustworthy fixer.
3. Preventative Maintenance – Check the Fluid Levels
Like the filter and radiator, your oil can also become dirty due to off-roading. Oil changes used to be necessary every 3,000-5,000 miles, but newer models could go up to 10,000 miles. The frequency of your oil changes depends on your trail trips, so weekly rides could accelerate the timeline. Check your oil and oil filter for dirty conditions to gauge the change.
Other fluids in your rig need topping off besides oil. Coolant might be the most important because of how hard the engine works on the trail. This component keeps your engine at a constant healthy temperature. Bring a backup supply of coolant, transmission fluid, brake fluid and power steering fluid if you go on a long trip.
4. Preventative Maintenance – Prevent Rust
Rust prevention is one of the most underrated preventive maintenance tasks. This chore is necessary because your vehicle could endure damage on the trails. Rocks could scratch your paint job when it hits the gravel. The exposed metal is more susceptible to sun damage and oxidation, inviting rust into the picture and risking internal damage.
Fortunately, you can utilize rust prevention methods for off-roaders. Undercoating is excellent because it inhibits rust formation where you have open spots of paint. Cavity and exterior waxes also work because they shield metal from outside conditions. Before applying these products, clean the vehicle's surface and remove all moisture. A good car wash sets up the waxing, so grab your soap and buckets for the next task.
5. Preventative Maintenance – Thoroughly Clean the Vehicle
Returning from the trail leaves plenty of mud on your truck or SUV. While dirt is a badge of honor, you need to clean your vehicle thoroughly. Take pictures to show your friends and get the pressure washer ready. This tool is excellent for quickly cleaning the dirt and mud off your machine, though be careful with the PSI and choose a safe nozzle.
Off-roader cleaning is essential year-round because of the different conditions for each season. For instance, winter rides create salt and chemical buildup in the undercarriage, so regular washes are necessary. Be gentle with your vehicle's exterior by hand-washing and drying it with microfiber towels. A gas station car wash could work if you're short on time, but manual washes are preferable because you know your vehicle best.
Ensuring Smooth Rides With Preventative Maintenance
Caring for your off-road vehicle involves regular maintenance to find preventable problems. You're more likely to find leaks or rust spots that cause long-term harm if you inspect it after every trip.
Prioritize the engine, suspension and paint job during maintenance. Your inspection should also include fluid levels, transmission, brakes and other critical components. If necessary, take your vehicle to a trusted mechanic to ensure you don't miss anything. That way, you'll always be ready for your next adventure.
The post 5 Need-to-Know Preventative Maintenance Tips for Off-Roaders appeared first on AllOutdoor.com.
Source: 5 Need-to-Know Preventative Maintenance Tips for Off-Roaders
