  • Moultrie Ranch Series Adds 3 New Accessories for 2024
    Read 189 times
The Moultrie Ranch Series of game and wildlife feeding products is getting 3 new introductions for 2024 to make managing your herd even easier. Their new products encompass areas of food delivery (chutes), grain/food storage (troughs), and even more hands-free power management in attachable solar panels to cut down on your power bill potentially. All of these are small, nuanced ideas, but can make anybody’s life a lot easier out in the field or at home.
Moultrie Coverage on AllOutdoor
Moultrie Ranch Series Dual Chute
The Moultrie Ranch Series Dual Chute has an MSRP of $59.99 and is meant to divide your herd so you don’t have everybody competing for a single spot for feed. Th Dual Chute is constructed of sturdy metal, and you can seamlessly run two Dual Chutes for a harmonious feeding time. These will work for both large grain/pellet feed as well as smaller sizes. The rest of the specs can be read below as presented by Moultrie.
  • Dual feed chutes extendable up to 18.5″ and capable of rotating 180°
  • Sturdy metal construction
  • Designed for feeding pellets and other small-to-medium-sized kernel feed
  • Pair up to two Ranch Series Axis Troughs (sold separately) for seamless automatic feeding on both sides
Moultrie Ranch Series Axis Trough
The Moultrie Ranch Series Axis Trough adds versatility to your feed operation by being able to hold up to 5 gallons of feed at a time, and the pre-drilled drain holes will ensure your livestock don’t need to go swimming or hold their breathe to get some food. Moreover, the Axis Trough can be paired with a bevy of other products from Moultrie to make for a truly customized and personalized feed setup. The Moultrie Ranch Series Axis Trough has an MSRP of $99.99 per unit.
  • Powder-coated metal construction
  • Multi-angle adjustment capability (0°, 15°, 90°, 180°)
  • 5-gallon volume capacity
  • Drain holes prevent water pooling in the bottom of the trough
  • Compatible with all 300 and 450 lb. capacity Ranch Series feeders (sold separately)
Moultrie Ranch Series 12V Solar Panel
Compatible with the Ranch Series Auger and Broadcast Feeders, the Ranch Series 12V Solar Panel makes powering your feeder a breeze. The panel easily mounts to the feeder hopper’s lid using existing hardware, and the wire with a 6-ft. metal conduit passes through to the battery via grommets built into the hopper and feeder kit. Metal collets are included to secure the wire conduit, preventing any interference from varmints. This solar panel ensures a continuous and sustainable power source for your feeder, reducing the need for frequent battery changes. The Moultrie Ranch Series 12V Solar Panel has an MSRP of $59.99.
  • 12V solar panel extends the battery life of your Ranch Series Auger and Broadcast Feeders
  • Use with any 12V rechargeable battery with F1 terminals (sold separately)
  • Connects to battery with standard insulated slide connectors
  • Metal wire conduit protects against damage from varmints
The post Moultrie Ranch Series Adds 3 New Accessories for 2024 appeared first on AllOutdoor.com.
Source: Moultrie Ranch Series Adds 3 New Accessories for 2024
Similar topics (1)
