2,107 Topics
66 Peak Today
  • Starlink or LTE : Which is Better When The Grid Goes Down?
    Read 55 times
TL;DR
  • This article is for off-grid builders planning to integrate wide-area communications into a code-aware electrical system
  • Starlink is viable as a primary link if you can supply about 1.7–1.8 kWh per day or run on a scheduled work window, maintain a clear sky dome, and add automatic LTE failover
  • Your site powers the terminal; traffic exits through ground gateways. Inter-satellite laser links can route to distant powered gateways during a regional outage, but extreme, wide-area events can still degrade service until backhaul is restored
  • Plan about 70–75 watts continuous for terminal plus router; require unobstructed sky above roughly 25–30 degrees elevation for stable real-time calls
  • 24/7 operation generally begins around 600–1,000 watts of PV and 4–6 kWh of LiFePO₄; an eight-hour work window often works with 200–400 watts of PV and 1–2 kWh of LiFePO₄
  • Use Starlink as primary only when power, sky view, and LTE failover are solved; otherwise choose a directional LTE path first
Grid-down connectivity should remain an operational requirement for many homesteads and not a mere slogan. Starlink is a satellite internet system that uses a self-aiming dish and low-earth-orbit satellites to deliver broadband where trenchable fiber or reliable fixed wireless do not exist. If you run client work, remote instruction, or site monitoring, a sustained outage is lost revenue and diminished awareness. This assessment treats Starlink as a designed subsystem that you power from your own solar, battery, or generator. Traffic moves through satellites and exits via ground gateways on terrestrial backhaul, which means the link can route around some local failures but still depends on powered infrastructure somewhere on the ground.
The question is not whether the technology is impressive; the question is whether it is the right primary pipe for your site conditions, energy budget, and risk posture.
Starlink delivers broadband-class throughput and latency that support conferencing and cloud workflows. It is independent of your local utility drop because you provide the power, which can allow continued service when neighborhood cable or fiber is dark. It is not independent of ground infrastructure in absolute terms, because user links still traverse gateways tied to terrestrial networks. That mixed dependency is what you design around: enough energy on site to run the terminal when you need it and a second transport path to absorb policy shifts, congestion, or gateway issues.
Power Budget And System Sizing
Continuous draw is the governing constraint. A conservative design value for the terminal and router is about 70–75 watts, which is roughly 1.7–1.8 kWh in a full day. If you intend to operate only during office hours, the daily energy drops to about 0.6 kWh and the storage and array requirements change accordingly. Higher DC bus voltages such as twenty-four or forty-eight volts reduce conductor size and conversion losses and simplify integration with a quality inverter or a DC-DC supply sized for steady load plus margin.
Site Conditions And Link Stability
Low-earth-orbit tracking requires a clean sky dome. Brief obstruction from trees, a chimney line, or nearby terrain introduces short interruptions that a browser can mask but a live call cannot. Before you buy, run the obstruction tool at the exact mast location and confirm a clear arc above roughly twenty-five to thirty degrees elevation. If you cannot achieve that without pruning or a taller structure, model LTE as your primary path.
Starlink Decision Framework For Grid-Down Use
starlink-main-image
Screenshot
This framework replaces guesswork with three pass-fail checkpoints. If any fail, it's best to treat LTE as a more ideal primary and revisit later.
You begin with sky clearance. Use the Starlink obstruction check at the proposed mount point at three different times of day and look for a clean report with minimal predicted events and a clear arc above the stated elevation. You then size the power system against your duty cycle rather than an abstract "always-on" assumption. Plan about 1.8 kWh per day for continuous operation, which typically implies several kilowatt-hours of usable storage and a mid-sized PV array, or plan roughly one third of that if you will schedule the terminal to run only during work hours.
Finally, require automatic LTE failover if your homestead depends on conferencing, voice over IP, or remote access, because policy changes and congestion are a certainty over a multi-year horizon.
For readers who want numbers in one place after that reasoning, here is the compact version. This list is not a substitute for the steps above; it mirrors them for quick reference after you have done the checks.
  • Approve Starlink as Primary when the obstruction survey is clean, the power system can meet the calculated kWh with at least three days of autonomy, and a dual-WAN router with LTE failover is part of the design
  • Approve LTE as Primary when the site cannot meet the sky or energy requirements, or when measured LTE with a directional antenna meets work needs with far lower draw
Installation That Respects Code And Roof Warranties
A reliable link starts with correct mechanical and electrical practice rather than exotic hardware. Choose a flashed, lag-bolted mount into rafters on a pitched roof or an engineered ballast mount on a flat roof after you verify exposure category, setbacks, and structure.
Then, bond the mast to the building grounding electrode system with short, straight conductors. Add surge protection on the power-over-Ethernet run at the entry point and at the rack. Use outdoor-rated cable with compression fittings and sealed penetrations with drip loops. Place a dual-WAN router upstream of your switches and access points so Starlink and the LTE modem occupy separate WAN ports and health checks govern failover. This approach allows local services such as storage and cameras to remain useful on the LAN even when both WAN links are down.
Operating Strategy For Energy And Workload
Operations policy has as much impact on energy cost as hardware selection. If you do not need overnight connectivity, schedule the terminal to power during working hours and shut down outside that window to avoid idle consumption and heater cycles in cold weather. Use wired Ethernet to the workstation for meetings and schedule large transfers during solar-positive hours. If you use a generator, keep the rack on a small line-interactive UPS so the link rides through transfer events without rebooting.
Cost And ROI
starlink-LTE
Screenshot
Starlink service in the United States runs about one hundred twenty dollars per month for residential plans, which is roughly one thousand four hundred forty dollars per year, with occasional promotions that change kit pricing. The capital outlay that matters to an off-grid site is the incremental energy system required to run the terminal when you need it. A round-the-clock profile typically implies several kilowatt-hours of LiFePO₄ storage and a mid-sized PV array; a work-hours-only profile often functions with roughly one third of that.
The economic test is simple: compare one day of lost income to the annualized cost of service plus the incremental battery and array capacity the terminal requires. If a single lost day has a value above a few hundred dollars, a scheduled-runtime configuration usually pays for itself; if your workload is light and your cellular signal is strong, an LTE-first design remains the lower-cost primary with Starlink added later as redundant capacity.
Starlink During Solar Storms
Space weather affects both satellites and the radio path that connects your dish to the constellation, so the correct question is not whether Starlink is immune, but how it behaves under real disturbances and what that means for a homestead. During the severe geomagnetic storms of May 10–12, 2024, SpaceX acknowledged "degraded service," and independent measurements reported increased latency and pockets of packet loss rather than a complete network collapse. NOAA categorized that period as a G5-class event, the most intense level and the strongest since 2003, and invited impact reports from communications operators because multiple technologies saw effects.
In practical terms, users with clear sky and healthy power experienced slower and less stable links but often remained connected; users on marginal sites or with obstructions saw more pronounced issues.
A separate risk appears during launches and at very low orbital altitudes, where geomagnetic storms thicken the upper atmosphere and increase drag. In February 2022, a moderate storm caused about forty newly launched, low-altitude Starlink satellites to reenter prematurely. That event did not reflect the behavior of the operational network at nominal altitudes, but it does illustrate that solar activity can force operational adjustments and, in extreme cases, accelerate the retirement of aging units.
For an end user, the operational takeaway is straightforward: even with inter-satellite laser routing that can reach distant powered gateways, the user-to-satellite radio link still crosses the ionosphere and can degrade during severe storms, so you plan for temporary performance hits and you keep LTE failover ready.
When To Choose Starlink, When To Walk Away
Starlink is the correct primary path when the obstruction survey is clean, the power system can meet the calculated kWh with margin, and automatic LTE failover is part of the design. LTE or fixed wireless should come first when the site sits under heavy canopy or complex terrain that you cannot fix with a practical mast, when winter heater draw cannot be supported even with scheduling, or when measured cellular performance already meets your workload at a fraction of the power. The goal is not to own a specific device; the goal is to maintain a usable, testable pipe on ordinary days and during grid-down events.
Up Next:
Survival Life's Ultimate Guide to SHTF Preparedness Plan
Survival Tech: Accessing Crucial Information When The Grid Goes Down
If you're looking for useful survival gear that you can't make at home, check out the Survival Life Store! What do you think of this post on the 10 Must Have Items You Need When Hiking With Your Dog? Let us know in the comment section below.
Source: Starlink or LTE : Which is Better When The Grid Goes Down?
TL;DR
starlink-main-image
Screenshot
Cost And ROI
starlink-LTE
Screenshot
Up Next:
