  • DIY Swamp Cooler: How to Cool Small Spaces Without AC
    Read 3,785 times
In late June, the U.S. average temperature climbed to 71.2°F which is nearly 3°F above normal. Air conditioning can effectively beat the heat, but it comes with a high electric bill. A DIY swamp cooler offers an affordable way to chill your space using a simple fan setup. This guide covers a foam‑box tutorial and provides several tips to keep your cooler running cold all season.
What is a Swamp Cooler?
A swamp cooler is a DIY appliance that helps lower room temperature via evaporation. A small fan pulls warm room air inside the box, where it moves across a wet pad or ice. The cooler stream then exits through the outlet vent.
Several DIY swamp cooler designs follow this same evaporation principle. One option uses a five‑gallon bucket and a water pump to circulate water through coils. Another method involves wrapping copper tubing around a fan grid and pumping cold water. You can also repurpose an ice chest by cutting air vents and fitting PVC ducts to channel cool air.
How to Build a DIY Swamp Cooler Using a Foam Box
The container method uses an insulated styro box as the housing unit of a small evaporative cooler. Since the container is light, you can move it easily and set it up quickly.
Materials
  • Insulated foam cooler or polystyrene box
  • Box fan (10–12 in)
  • Submersible water pump (5–10 W)
  • ¼‑inch ID vinyl/PVC tubing
  • Evaporative cooling pad or foam filter pad
  • Zip ties or strong duct tape
  • Clean water
Basic tools
  • Tape measure
  • Marker
  • Utility knife or box cutter
  • Drill with ¼‑inch bit
Steps:
  1. Set the foam box on a stable surface and measure the fan's front dimensions. Then mark a circle on the box wall that matches those measurements.
  2. Cut out the circle so the fan sits evenly against the box. Next, drill a small hole near the bottom for the PVC inlet pipe.
  3. Place the small water pump at the bottom of the box and push the tube onto the spout. Then, guide it along the inside wall until the end reaches the pad's top edge.
  4. Set the fan over the opening and secure it with zip ties or tape. Then face the front toward the pad.
  5. Fill the foam box with clean water until the level sits about 1 inch above the top of the pump.
  6. Switch on the fan and the pump then watch the pad for a minute. If you see dry patches, turn the small knob to raise the flow until the surface looks evenly wet.
Cleaning and Maintenance Tips
After each cooling session, unplug the fan and pump then drain the bucket. Then, rinse the pad and let it air dry. Additionally, wipe the foam box and clean the pump to keep the flow steady. At the end of each week, run a mild vinegar solution through the pad, then flush the bucket and tubing. If the pad starts to smell or turns brittle, replace it immediately to maintain clean airflow and consistent cooling.
DIY Swamp Cooler: A Low-Cost Fix for Hot Days
While a DIY swamp cooler won't replace central AC, it can cool small rooms effectively. This cooling device will not only help you save on energy costs but also keep you comfortably cool all season long.
FAQs: DIY Swamp Cooler
  1. What is a DIY swamp cooler?
    It's a homemade device that uses water and a fan to cool air through evaporation.
  2. Does it work like an air conditioner?
    Not exactly. It lowers the temperature using moisture instead of refrigerant and works best in dry climates.
  3. What materials do I need?
    You'll need a foam cooler, a small fan, a water pump, tubing, a filter pad, and basic tools.
  4. How much does it cost to make?
    Most people can build one for under $40 using common parts.
  5. Where should I use it?
    Use it in small indoor rooms like bedrooms, garages, or workshops where airflow is limited.
  6. How often should I refill the water?
    Check every few hours. In hot weather, you may need to top it off 1–2 times a day.
  7. Do I need to use ice?
    Not required, but adding ice or ice packs can boost cooling for a short time.
  8. How do I clean it?
    Rinse the pad and tubing weekly, wipe the cooler interior, and drain any leftover water.
  9. Can it run all day?
    Yes, as long as there's water in the box and the pump stays submerged.
  10. Is it safe to leave unattended?
    It's generally safe, but check for leaks, secure wiring, and don't run it near electronics or outlets.
Source: DIY Swamp Cooler: How to Cool Small Spaces Without AC
Materials
  • Clean water
Basic tools
  • Tape measure
  • Marker
Steps:
