  • Real Avid Compact Smart-Torq Adjustable & Fixed Limiter Torque Systems
    Read 2,103 times
Real Avid has announced a new Smart-Torq Fixed Limiter Torque System as well as a Compact Smart-Torq Adjustable Limiter. So, whether you want to have all of the adjustment you need in hand, or simply want to pick-and-choose as your situations and demands call for, you have lots of options with these new gunsmithing tools that’re being announced by Real Avid.
Real Avid Coverage on AllOutdoor
Real Avid Compact Smart-Torq Adjustable Limiter
The Real Avid Compact Smart-Torq Adjustable Limiter is not listed on Real Avid’s website (yet), and there is no openly stated MSRP at this time either. Once it becomes available, you will be able to purchase it as an individual gunsmithing tool, or in a package: the new Real Avid Smart-Torq® Adjustable Limiter and X3 Driver™ Kit. That aforementioned kit includes:
  • Adjustable Limiter
  • NEW X3 Driver™ — Modular Unit that incorporates 3 Driver Systems: Ratchet, T-Handle, and Screwdriver
  • Assortment of Common Driver Bits, Hex-to-Square 1/4″ Adapter, 1/2″ Socket
  • Compartmentalized Hard Plastic Case
The Smart-Torq® Adjustable Limiter is a precision-manufactured, precisely tuned in-lb torque limiter developed specifically for firearm applications. The compact, sleek design stows neatly in the toolbox or on the work bench and is ergonomically designed to ensure a positive grip for securing even high-torque screws.
With the Smart-Torq® Adjustable Limiter, users can adjust for any torque value between 15 and 65 in-lbs. This range covers nearly all scope mount, scope ring, and action screw torque requirements, and does so down to 1 in-lb increments.
Real Avid Compact Smart-Torq® Adjustable Limiter
Real Avid Smart-Torq Fixed Limiter Torque System
At this tie, Real Avid does not have these listed on their website, but they should be made available soon in a plethora of torque limiter ratings. Sold individually, these torque limiters are available in 7, 10, 12, 15, 18, 20, 25, 30, 35, 45, 50, 65, 80, and 100 Inch-Lb ratings. Each limiter has an MSRP of $24.99. To use, simply install the appropriate Smart-Torq Fixed Limiter to any 1/4-inch driver, fit with the correct driver bit, and tighten the screw. The limiter will "click" when the rated torque value is reached. That's it.
Achieving the precise torque value on scope mounts, rings, actions screws, and other assorted gun components is critical to firearm performance and to prevent damage to components. Not enough torque and scopes come loose, barreled actions become sloppy, and components may fall off. Too much torque and bad things happen to optics and guns.
Recognizing the critical need for precision at the gun bench, Real Avid developed a simple, cost-effective means to achieve correct torque with their new Smart-Torq® Fixed Limiters. These fixed torque limiters, built for 1/4-inch drivers, are pre-set to the most common in-lb torque specifications found in gun builds and component upgrades.
As always, let us know all of your thoughts about Real Avid and their new Smart-Torq Fixed Limiter Torque System and Compact Smart-Torq Adjustable Limiter in the Comments below! We always appreciate your feedback.
Real Avid Social Media Channels
The post Real Avid Compact Smart-Torq Adjustable & Fixed Limiter Torque Systems appeared first on AllOutdoor.com.
Source: Real Avid Compact Smart-Torq Adjustable & Fixed Limiter Torque Systems
Similar topics (3)
